When in drive or reverse the car will not move
2009 DODGE CALIBER
120,000 MILES
PATRICK COLBORN
The engine runs fine. At first it was making a lot of noises and the car would jerk around. However, now it runs fine. But, when I put it in drive or reverse, the car will not move.
Dec 19, 2017 at 4:44 PM
CARADIODOC
  • 34,306 POSTS
You need a live person to look underneath. Please also list the engine size and transmission type. You did not say where the noise is coming from, what it sounds like, or what the moving around felt like. As a guess, I would start by looking at the two front half shafts. If a joint broke, neither front wheel will turn under power. To check for this, shift to "park", then try to push the car forward and backward. If it will move, something allowed one of the half shafts to come apart.
Dec 19, 2017 at 5:07 PM
PATRICK COLBORN
It is a automatic front wheel drive, four cylinder. The noise seem to have been coming from the driver side front wheel.
Dec 19, 2017 at 5:33 PM
JAMIECONWAY88
  • 6 POSTS
I think you should check transmission fluid levels. Because excessive transmission leaks or detached fluid lines can quickly empty your transmission of critical fluids. And without fluid, your transmission will become seriously damaged.
Dec 19, 2017 at 5:37 PM
CARADIODOC
  • 34,306 POSTS
Try moving the car when in "park".
Dec 19, 2017 at 5:39 PM
PATRICK COLBORN
I will check the fluids tomorrow and also see if it will roll while in park as well. I will message the response tomorrow.
Dec 19, 2017 at 5:43 PM
Dec 20, 2017 at 6:31 PM
