What happens to engine if running in ilde for more time
2015 HONDA CITY
KIRANPATIL
I need to use a car as generator so i would run it in idle for 10 Hours. I tap output from alternator and use it as a power source.
What will happen to engine if i run it in idle for so much time?
Nov 11, 2014 at 8:52 PM
JOHNNYT73
  • 924 POSTS
No issues should occur. You have to think if you have ever driven a car for more than 10 hours straight on a hot highway. All you need to do is make sure your engine oil is not within a few hundred miles of needing to be changed, and of course your fuel level is good. Don't run any accessories in the car such as radio, A/C, heat, or anything of that nature.
Nov 12, 2014 at 6:12 AM
