What does it mean when the Tow/haul flashing?
2006 FORD F-350
170,000 MILES • 5.4L • 4WD • AUTOMATIC
KEYONDAVIERA
Just changed the camshaft sensor and now my tow/haul is flashing. I’m not sure what to do next.
Dec 4, 2021 at 3:03 PM
Which sensor was replaced? Was it on the left or right side? Also, did you check fuse 2.24 in the central junction box? It powers the tow/haul switch. See pic 1 below for the location.
When testing it, first confirm the fuse is good. If it is, confirm there is power to it. Here is a link that you may find helpful:
Let me know what you find. Also, let me know if you disconnected anything other than the CMP. I looked through the wiring schematic and noticed many wires near or around the cam sensor at the PCM are tied to the transmission.
See pic below.
Dec 4, 2021 at 8:52 PM
