Last evening my engine stopped with a slight thud while getting off the freeway. No bad smells, engine didn't turn over trying to restart. Check Engine flashed code 12 when I jumped the terminals.
Some information I've found suggests it's the knock sensor that's the issue. Others say it's something within the distributor, and a new distributor is in order.
93 22RE 2.4L. Wondering if anyone else has any experience with this while I figure out what to replace.
Recently adjusted the valves and the mileage dropped a bit. and there was a "put put" noise at lower RPMs if that helps.
Jul 8, 2025 at 12:07 PM
