Multiple codes
2006 FORD EXPEDITION
200 MILES • 0.8L • V8 • AUTOMATIC
TAMANDA88
what do I need to replace on the vehicle listed above Eddie Bauer Edition? codes are: p0010,p0020,p0102,p0104,p0135p0141,p0155,p0161,p0443,p0446,p0622,p0731,p0740,p0743,p0748,p0748,p0750.
Sep 26, 2020 at 10:33 AM
Good afternoon,
Lots of codes. The chances of all these systems failing at the same time is very low.
I would start the truck and check the charging system and see if it is charging. The voltage should be 14 to 14.5 volts. Then switch the meter reading to AC volts and see if there is any reading.
Beyond that, I would clear the codes and see which one returns first.
Sep 26, 2020 at 2:40 PM
