Engine light came on one day so i checked the code but i am unsure what i need to do about it. Any advice or help would be appreciated.
Jun 25, 2025 at 6:49 AM
CERTIFIED EXPERT
Yep, this means the voltage in the system is too low, when the engine is running do you have a battery warning light on? If so the alternator might be to blame as it is not charging.
P1633 - Keep Alive Power (KAP) Voltage Too Low
You can use this guide to confirm the alternator is working okay and if so, I would replace the battery.
Battery light would come on once in a blue moon but when i tested my battery and alternator the tester said they were good, but the battery is starting to get old so i could try replacing that.
Jun 25, 2025 at 4:50 PM
CERTIFIED EXPERT
Okay, also, check all fuses int he under hood fuse panel, you might have one that is out.
