Hi guy's! I have a 1998 GMC Sonoma with the 4.3 in it. But a 1990 engine was swapped out before I bought it. My question is, can I use a 1998 distributor on a 1990 engine? My manual is from a 1994 to 2004 and it says somethings that question like, using the number four cylinder instead of the number one cylinder when timing the engine and that the 1/6 are correlating cylinders. I am having a misfire problem according to my scanner on number six and although the compression is 125 in that cylinder as apposed to 130 to 140 for the rest. I cannot seem to line up my timing marks together! I replaced my timing chain and gears and made sure that the dots were lined up, and made sure that the number one was up on number one TDC to put my distributor in and lined it up on the number six on the distributor base. I was just wondering if the incorrect distributor was the problem of not lining up my marks! Everything runs alright, although my scanner says that I have a misfire on the number six, but it starts good and cuts off good. I am very confused!
Thank you
Thank you
Sep 24, 2018 at 9:21 AM
