What would cause my engine not to start up?
2003 FORD F-150
230,784 MILES • 5.4L • V8 • 2WD • AUTOMATIC
MAIRIGA
My car started mixing up. i changed the whole plugs and serviced the nozzles. after some days of usage it resumed mixing up again. The car suddenly stopped starting. the mechanics and automobile electricians queried: lack of fuel, starting sensor, fuel pump and then brain box. Until now no solution is reached. What else can i do?
Oct 16, 2020 at 8:57 PM
We need to start with finding out what we have and what we don't in order to start the vehicle. You need spark, fuel, and compression. Here is a guide that helps with this:
https://youtu.be/dCjmRL3p4Cs
We need to start with checking fuel pressure. Here is a guide for that:
Then we need to find out if there is spark. We do that by pulling a plug and holding it against the engine and crank the engine to see if it sparks.
Lastly we need to check compression. Here is a guide for that:
Once we know the results of these items we will know what direction to go. Clearly we could guess at what is next but we need to find out where we stand with what we have and do not have and then we can determine next steps. Thanks
Jan 20, 2021 at 10:12 AM
