What could be the issue for the cluster to not buzz to an open door?
1991 VOLKSWAGEN CORRADO
84,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
SCION
  • 41 POSTS
The old owner has converted my Corrado from a G60 Auto to Manual. What could cause the instrument cluster to not buzz to a key in ignition, with a door open?
Apr 16, 2024 at 6:40 AM
It sounds like the key warning switch inside the ignition key tumbler has gone bad, I would check all fuses and then switch the ignition lock out for a new unit. Check out the images (below). Please let us know what happens.
Apr 16, 2024 at 9:55 AM
SCION
  • 41 POSTS
The old owner said he replaced the key cylinder. What wire enables the buzzer? Maybe it's the seat, because under the seat its disconnected, causing it to not buzz. My 06 Scion xB does this when the seatbelt buzzer is disconnected.
Apr 16, 2024 at 11:47 AM
Yep, that could do it, can you connect the wiring under the driver seat to see if it fixed the problem?
Apr 17, 2024 at 9:25 AM
SCION
  • 41 POSTS
It's because i am missing the buzzer relay that plugs into the fuse box, just like the blinker relay.
Nov 29, 2024 at 3:15 PM
Okay, that makes sense, have you replaced the relay, does the buzzer work now?
Nov 30, 2024 at 10:54 AM
SCION
  • 41 POSTS
No i have not replaced it. I was researching why it was not and apparently most VWs like Passat's, my Corrado, Jetta's and Golf have this buzzer Relay, of course on older models. But once you plug it in you should have it working.
Nov 30, 2024 at 10:57 AM
Sounds good, I am glad you got the problem figured out.
Nov 30, 2024 at 11:40 AM
