Code 982C ECM faulty signal
2003 VOLVO S60
143,000 MILES • TURBO • 4WD
NWAMAKAEZEANOCHIE
Car starts sometimes and finally stopped. check starter, changed battery and still will not start. Now only key is lost.
Reprogrammed a new key and car still will not start.
DTC code reads 982C ECM faulty signal.
What is wrong?
Dec 8, 2017 at 5:05 AM
It sounds like you have an ignition key that did not take the reprogram. Also, is the security light flashing when you try to crank it over?
Check the system fuses to see if one is out causing the communication error.
Here is a guide to help:
Here are the fuse locations please check them with the key on.
Check out the diagrams (below).
Dec 9, 2017 at 6:55 PM
NWAMAKAEZEANOCHIE
Sorry, the correct code is 928C ECM faulty signal and yes the security light did go off.
I will be checking the fuses again... I guess you mean if there are blown/bad fuses....
Dec 10, 2017 at 4:19 AM
NWAMAKAEZEANOCHIE
Another doc was a bad plug... number 5 but my mechanic says it's not enough to cause problems like cranking cause the car didn't even crank
Dec 10, 2017 at 4:22 AM
It wont crank with the security light flashing. Here is a guide to help you reset the security system
https://www.2carpros.com/articles/how-to-reset-a-security-system
Dec 15, 2017 at 1:15 PM
