What cause engine piston to break and make hole on the engine block
2010 CHEVROLET TRAVERSE
145,000 MILES
JEAN BERNARD CHOUDJA
Hi, I recently (two and half months ago) got the timing belt changed. a week ago, as I was driving on the free way, I heard a big bang and the engine stooped. My insurance appraiser looked at it and find there were a hole on the engine block and peaces of the piston where everywhere. He told me my timing chain might have been broken and that is what caused the damage. I want to make sure the timing failure can cause the issue. If no what can be the reason of the issue?
Jun 7, 2017 at 3:06 PM
HMAC300
  • 48,601 POSTS
timing chains when they break will et the valves hit the piston and if at a higher speed will damage an engine like you describe. I think when you said timing belt was replaced you meant accessory belt for A/C alternator etc. that is different from a timing belt. your car has a timing chain. also poor maintenance can cause early failure like yours. meaning oil needs to be changed at 4,000-5,000 mile intervals.
Jun 8, 2017 at 6:18 AM
Thank you for your answer. I made a mistake. The timing chain not belt was replaced by a mechanic.
Jun 8, 2017 at 7:57 AM
HMAC300
  • 48,601 POSTS
if it were done recently then it may have been of poor quality or no tension-er's were replaced as they should have been . guess the mechanic is getting you another engine. or it is see you In court keep your receipt from the repair as proof.
Jun 8, 2017 at 12:03 PM
