Will not start
2008 DODGE NITRO
202,000 MILES
RICHARD MUELLER
  • 4 POSTS
I replaced fuel pump and a couple of relays. We have spark and air. It will run for a few seconds on starting fluid. I can't think of any thing else. Please help!
Jan 4, 2019 at 10:35 AM
Good afternoon,
I would start by doing a fuel pressure test. if you can start with priming, you have spark and compression.
Did you use a new fuel pump?
Beyond that you need to get a noid light and check the injectors to see if the PCM is commanding them to flow fuel.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Jan 4, 2019 at 10:46 AM
RICHARD MUELLER
  • 4 POSTS
Yes, the pump is brand new.
Jan 4, 2019 at 10:47 AM
Okay, then you need to check the fuel pressure and the noid light.
Jan 4, 2019 at 10:51 AM
RICHARD MUELLER
  • 4 POSTS
Okay. I will do that. Thank you
Jan 4, 2019 at 10:53 AM
You are welcome.
Glad to help.
Jan 4, 2019 at 11:31 AM
RICHARD MUELLER
  • 4 POSTS
Well I have no power to the fuel pump. And all the wires look fine. Any ideas ?
Jan 6, 2019 at 1:06 PM
The TIPM or the fuse box controls the fuel pump. check the fuse listed in the diagram for power on both sides when cranking.
Jan 6, 2019 at 1:39 PM
