The procedure is fairly straight forward, you can get to the switch by removing the driver front wheel. See the instructions below and the diagram attached:
Removal Procedure
Notice: When removing or installing the backup lamp switch, do not use an open-end wrench. Use only a socket in order to avoid damage to the switch assembly.
1. Remove the left front wheel.
2. Disconnect the backup lamp connector (1).
3. Remove the backup lamp switch assembly.
Installation Procedure
1. Notice: Refer to Fastener Notice in Service Precautions.
Install the backup lamp switch. using pipe sealant Saturn P/N 21485278 or equivalent.
Tighten the switch to 33 Nm (24 ft. lbs.).
2. Connect the backup lamp connector (1).
3. Install the left front wheel.
Jan 6, 2025 at 5:11 PM
