I hear like a grinding noise when i drive my car on the highway. The noise comes at speeds above 50. There is also a lot of vibration. Not sure what this is? These are the things i have done to try to fix this problem:
CV axle change
Rotate tires and align
Spark plugs
Ignition coils
Air filter
Cleaned out throttle body
Intake gasket
I also had my mechanic check if there was anything loose and there wasn't. He also checked hubs and said was good.
Thanks in advance
CV axle change
Spark plugs
Ignition coils
Air filter
Intake gasket
Thanks in advance
Feb 26, 2020 at 9:35 AM
