Hi
I have a weird idling problem started 3 weeks ago when the car under no load at idling and parked the RPM goes up to 1,100 and revs to 1,800 to 2,000 and down and again 1,100 to 1,800, 2,000 and down. It keeps happening. it revs on it's own. under load A/C on or at drive it's okat 500 to 680 rpm. I did a scan using OBD2 scanner nothing I did a reset for the idling and RPM through the odb2 same thing I did clean the throttle body using a throttle body cleaner same thing. If you guys have any idea about what is happening I would appreciate the help. Some mechanic told me it might be the throttle body having a problem and going bad but the weird thing it happens only when the car under no load. Vehicle listed above is the base model with MPI engine.
For the history of repairs:
Before 6 months ago.
New spark plugs.
New ignition coils.
New air filter.
New transmission fluid.
New engine oil with filter.
Thank you. : )
New spark plugs.
New ignition coils.
New air filter.
Thank you. : )
Jul 27, 2020 at 10:48 AM
