Air conditioner works intermittently
2011 KIA OPTIMA
50,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
KYUNG JUN BANG
Most of the time it works. I had my AC on for hours while taking a road trip it failed only once for about fifteen minutes. I turned it on and off bunch of times then it turned on. When the AC is not working the engine makes different growl when gas is applied.
The cooling fan does turn on when I turn the AC.
It this a clutch or pulley issue?
Jul 22, 2018 at 8:24 AM
It sounds like the system is overcharged, but to be sure let's check the high side pressure and it would be helpful if you took a video of the noise with your phone and upload it here in your reply.
Here is a guide to help you see if the system is overcharged:
Jul 23, 2018 at 11:00 AM
