I had a mechanic look at my car because of a leak in the coolant underneath reservoir on the driver side. He has told me that the problem is that a weep hole on the water pump is leaking. I will need to put the money together for the replacement of the water pump. However, he said that there might be a short-term solution. He suggested I use Blue Devil to stop the leak while I get the money together.
Will this work?
Will this work?
May 29, 2017 at 5:14 PM
