Weak/no idle and sometimes will not start
1971 VOLKSWAGEN TRANSPORTER
96,000 MILES • RWD • MANUAL
TYLER TIMPNER
The bus drives for about five minutes and then the idle disappears and the engine shuts off when I come to a stop and then it will not start back up. The entire engine compartment in the back seem to be pretty hot after it shuts off. I have replaced the distributor cap, wires, spark plugs, and ignition coil and timed the distributor to get rid of all the back fire. Cannot figure out what is going on. please help!.
Apr 21, 2017 at 11:34 PM
KHLOW2008
  • 41,814 POSTS
The above link provides a full explanation of what you should be looking for. An engine needs three things to run; Compression, fuel and spark. You need to find out which is the part missing when it could not be started.
Apr 24, 2017 at 1:55 AM
