We do not have keys. Can I start it anyway without keys
1974 FORD PINTO
99,550 MILES • 4 CYL • 2WD • AUTOMATIC
PINTO2014
It's been sitting for years and I want to see if I can start it. I can't find the keys. Got new battery but no keys. Please is there any way I can start the pinto
Aug 8, 2014 at 4:09 AM
MHPAUTOS
  • 31,937 POSTS
Select park, jump power from battery to coil (+) this will give you ignition, remove small signal wire from starter solenoid, make a starter switch by using to lengths of wire, one end fit a female terminal to fit over the starter terminal, fix other end to one terminal of a push button switch, second wire fit to other terminal on switch and the last end goes to battery (+)push the button and the starter will turn, do not try and jump by shorting out the starter terminal with a screw driver as this can damage the starter.
Aug 8, 2014 at 4:55 AM
