Can I get the water pump torque specs?
2012 JEEP WRANGLER
125,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
HOLDERH
I am looking for the torque specs and the tightening sequence for the water pump and pulleys. Thanks in advance.
Feb 5, 2024 at 3:19 PM
If you look below, I attached the installation procedures. The torque specifications are different based on the bolt size (three different ones).
Additionally, it should be torqued in a specific pattern. That is included as well.
See pics below.
Feb 5, 2024 at 7:01 PM
HOLDERH
This is exactly what I was looking for. Thank you so much!
Feb 5, 2024 at 7:10 PM
You are very welcome. I remember a water pump took 45 minutes to an hour to replace. This is certainly not one like that.
If you run into trouble or have questions, let me know. Also, once everything is back together, slowly turn the engine by hand before trying to start it. Make three or four rotations to make sure nothing is making internal contact. If the timing is far enough off, it will cause internal damage.
Feb 6, 2024 at 8:31 PM
