can you get me the spec on the 5 bolts on the water pump bolts?
Sep 1, 2025 at 11:18 AM
MECHTRIX
CERTIFIED EXPERT
All 5 bolts are torque to 9nm. please click the diagram below.
Image (Click to enlarge)
Sep 1, 2025 at 8:38 PM
MECHTRIX
CERTIFIED EXPERT
Side note, keep in mind If you take off the belt pulley that bolt is reverse threaded. So to loosen is clockwise as to not break the belt. the belt pulley bolt torque is 10 nm plus 1/4 turn or 90°, but if you loosen it then it recommends replacing it with a new one.
let us know if there's anything else.
Sep 1, 2025 at 8:39 PM
BHAMDOC1973
MEMBER
Thanks. Ya i remember the bolt being reverse thread. thanks
Sep 2, 2025 at 5:03 AM
MECHTRIX
CERTIFIED EXPERT
Glad to help if there anything else you need be sure to ask.
be well
