That darn metal tube that goes into the new water pump, new Oring, is leaking.
I wanted to know if i could use the black RTV around the tube/Oring ? I see it's a common issue with these trucks.
I removed as much water as I could and dried up the inlet hole and spread a thin bead of black RTV then a bead around the pipe with Oring and pushed it in. Hopefully, i got the majority of water in pump out, with a pump hose, but it could slowly creep up since the hole faces up. I can let it set up for 8 hours.
Is this a good method or is there a better way to seal it?
Thanks
Thanks
May 11, 2022 at 1:20 PM
