Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Pontiac
G6
Engine Cooling
Water Pump
Replace/Remove
Water pump
2007 PONTIAC G6
137,781 MILES • 3.6L • V6 • 2WD • AUTOMATIC
LISA KEMPTER
MEMBER
1 POST
FOLLOW
I am getting ready to change out my water pump on my own. Any advice before I start would be helpful. Please and thank you.
Jun 12, 2018 at 9:09 AM
CERTIFIED EXPERT
Good afternoon.
Remove the belt and then follow the prodeure below.
Drain all the coolant as well.
Good luck.
Water Pump Removal
Tools Required
EN 46104 Water Pump Pulley Holding Tool
imageZoom/Print
1. Install the EN 46104 onto the water pump pulley.
imageZoom/Print
2. Remove the water pump pulley bolts.
3. Remove the water pump pulley.
Jun 12, 2018 at 10:46 AM
