Do I need to replace the entire water pump if the bearings are damaged or is it possible to just replace the bearings?
2017 BUICK ENCORE
81,000 MILES • 2WD
MCAL012
Water pump.
Jun 4, 2023 at 9:42 PM
The bearing is non-serviceable. They are sealed inside the pump. When they fail, the pump needs to be replaced as a unit.
I attached the directions below for you.
See pics below.
Jun 4, 2023 at 11:41 PM
