Can you have an internal leak with this water pump? I have seen antifreeze seeping into the timing chain area while doing a timing chain and head job. The only way i could get it to stop was to remove a 13mm drain plug on the bottom of the water pump housing .Could this be a sign of a faulty pump? I thought this pump was to leak to the outside. Can this come from not completely draining cooling system?
Nov 28, 2019 at 6:26 PM
