I replaced the lower intake manifold gasket and manifold. The manifold was severely pitted at the water ports. I also replaced the upper intake plenum and gasket. When I fill the radiator with water, water trickles through the throttle body via the round port. Also, my oil pan is getting water as water is mixing with oil. Does this mean my head gasket is blown? If yes, besides changing the head gaskets and head bolts must I take the heads to a machine shop for reconditioning? Any information is appreciated. Thank you!
May 8, 2021 at 9:12 PM
