Water leaking from engine
1998 CHEVROLET CAVALIER
170,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
CPHAMILTON1964
  • 6 POSTS
On the bottom of the engine on passenger side water is streaming out. Is this a freeze plug? If it is, how do I replace it?
Jun 1, 2017 at 5:05 PM
SATURNTECH9
  • 30,869 POSTS
Iam sorry but your my eyes I can't see where the leak is coming from and the information I have so far I can't say for sure where the leak is.Your going to have to get in there and see where the coolant is coming from.Could be the water pump or a hose.
Jun 2, 2017 at 1:05 PM
CPHAMILTON1964
  • 6 POSTS
Facing the car on left side it is leaking. It is too tight in there to reach hand inside to find exact spot. It is leaking clear water.
Jun 2, 2017 at 1:40 PM
CARADIODOC
  • 34,306 POSTS
Hi guys. Do you have red or green antifreeze in the cooling system? If you do, the clear water is likely condensed humidity from the AC system? Do you only see this leakage when the AC is running? Is the coolant level dropping in the reservoir?
Jun 2, 2017 at 10:15 PM
CPHAMILTON1964
  • 6 POSTS
The liquid runs out without the engine running.
Jun 2, 2017 at 10:45 PM
SATURNTECH9
  • 30,869 POSTS
What color is the coolant in the car?Also does the liquid smell sweet?
Jun 2, 2017 at 11:20 PM
CPHAMILTON1964
  • 6 POSTS
All of the coolant has leaked out so it's just water running out. I add water when I'm trying to find exact spot the leak is from.
Jun 3, 2017 at 10:23 PM
SATURNTECH9
  • 30,869 POSTS
Is it leaking from the back of the engine on the passenger side?
Jun 3, 2017 at 10:25 PM
CPHAMILTON1964
  • 6 POSTS
It is on the passenger side but I'm not sure if it's from the back. I don't think so but I'm not sure.
Jun 3, 2017 at 10:30 PM
SATURNTECH9
  • 30,869 POSTS
Again it's really hard for me to say where its leaking from you are my eyes so I need your input on what your seeing
Jun 5, 2017 at 8:08 AM
CPHAMILTON1964
  • 6 POSTS
It is leaking on the side of the engine - not the back of the engine.
Jun 5, 2017 at 11:09 AM
SATURNTECH9
  • 30,869 POSTS
So the belt area or by the radiator?
Jun 5, 2017 at 1:13 PM
SATURNTECH9
  • 30,869 POSTS
Any pics you can post?
