Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Explorer
Climate Control
Air Conditioner
Compressor
Leak
Water leak coming from under A/C compressor
1994 FORD EXPLORER
180,645 MILES • 6 CYL • 4WD • AUTOMATIC
BRIANHANKLA
MEMBER
1 POST
FOLLOW
It is not the water pump,or hose what could it be?
Apr 8, 2020 at 12:06 AM
CERTIFIED EXPERT
Good morning,
You need to pressure test the cooling system to pin point the source of the leak.
https://www.2carpros.com/articles/radiator-pressure-test
Around that area is the intake manifold gasket. That is common for leaking where it meets the head. It is a thin aluminum gasket that corrodes over the years.
https://www.2carpros.com/articles/replace-intake-manifold-gasket
I would start with a pressure test. You can rent a tester or have a parts store do it for you for free.
Apr 8, 2020 at 4:08 AM
