Water leakage
1995 TOYOTA TACOMA
224,000 MILES • 0.5L • 4 CYL • 2WD • AUTOMATIC
DALLAS FOSTER
I am leaking water from under the dashboard when air conditioner is running.
Jul 16, 2017 at 1:58 PM
SATURNTECH9
  • 30,869 POSTS
Sounds like your A/C drain is clogged. the A/C drain is usually on the center of the firewall it will be a hole or a rubber tube coming off of it. You can clear it with a metal coat hanger if it is just the hole. If it is a tube you should be able to clear it by massaging the tube to help push the blockage out.
Jul 16, 2017 at 5:14 PM
