I have a coolant leak at the bottom front end of my car
2006 CHEVROLET EQUINOX
139,000 MILES • 3.4L • 6 CYL • AUTOMATIC
CINIMON0922
I have a leak at the bottom front end of my car. I Keep adding both coolant and water in my reservoir tank and it instantly come out at the front end of my car. I was told it could be a hose to the radiator or it could be my whole radiator. Can I use one of those solutions to seal a leak in a hose to see if that's 5he problem or will that make it worst?
Jul 29, 2015 at 6:54 PM
I need to know where it is leaking from. A hose will continue leaking with sealant. It sometimes works if it is actually the radiator. Also, if it leaks right out of the overflow when you fill it, are you sure the jug isn't cracked or damaged or is the radiator going empty too?
This guide will help us
https://www.2carpros.com/articles/car-is-leaking-coolant
Apr 20, 2021 at 2:11 PM
One other thought. If you do use a radiator sealer, I don't recommend anything that is an aluminum powder. I can't recommend product names, but get a product that is in a smaller bottle, brown in color and has rubberized pellets in liquid. That is the only one I know of that won't plug a heater core.
MISZLOVELY09
  • 4 POSTS
It's coming from bottom near the radiator at bottom of the car
Does it leak as you fill the overflow? It could be from a few places where you see it.
MISZLOVELY09
  • 4 POSTS
Once I fill the overflow up about 5 seconds later it' starts leaking from the bottom
MISZLOVELY09
  • 4 POSTS
The radiator still has water in it
If that happens when the engine is off and cool, it honestly sounds like the overflow is leaking. But that wouldn't cause the radiator to get low and the engine to overheat. The only thing I can say is you need to check along the side of the radiator above where you see the drip under the vehicle. See if it is wet indicating the leak is above the hose.
MISZLOVELY09
  • 4 POSTS
I found the problem is was the radiator tank had a big crack and would only leak under pressure. I replace it with one I got from amazon worked perfect. I used this guide to help me with the steps to change it.
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
thanks you guys, this site is nice.
Good to hear, please use 2CarPros anytime we are here to help.
