After finishibg the timing chain job including a new water pump car runs great then fan comes on even though its not running hot, no codes. I see water dripping from around the crank shaft pulley, checked the water pump hose that goes to water heater its fine checked around water pump am not seeing anything leaking. Checked thermostat not leaking. Also the reaervoir is full and boiling and the hose around it which has no clamps starting to leak some mist from the pressure. The low radiator hose going to thermostat is not full or that hot. Am not sure what is going on. Car was not running hor before the chain job
Jan 17, 2026 at 12:20 PM
