Water keeps disappearing from the reservoir
2002 CHRYSLER CONCORDE
125,000 MILES • 2.6L • V6 • 2WD • AUTOMATIC
JUSTME4355
This is the LXi model. The water level in the radiator keeps going down. I do not see any leakage on the ground, yet I still keep having to keep the reservoir filled by adding more water or antifreeze.
What is the problem and how is it fixed?
Jul 2, 2017 at 7:00 AM
HMAC300
  • 48,601 POSTS
rent a pressure tester from auto parts, if no leaks seen externally it may be a head gasket leaking into cylinder.
Jul 2, 2017 at 8:49 AM
