Coolant light on
2006 BMW 118I
215,415 MILES • 2WD • MANUAL
THABANG NICHOLAS BOOYSEN
  • 9 POSTS
Coolant light in dash board does not disappear and the water is full.
Water coolant light still shows but the gauge is okay and it has been blow still the temperature is normal.
Jun 15, 2018 at 3:44 PM
This vehicle is equipped with a coolant level sensor which is located in the reservoir. I have attached a picture of one for you to see. Unfortunately, I do not have a picture for your model, but it should be very similar. The picture is of a 2006 323i. Most likely, either the switch is bad or it has a bad connection. Check that first. In the picture, number one points at the sensor.
Jun 16, 2018 at 8:49 PM
  • 9 POSTS
Hi Mr Joe. I managed to change the sensor but the light still appears.
Jun 18, 2018 at 6:06 AM
Check to make sure the wiring to the sensor is in good condition. Also, make sure the plug is not damaged or corroded. The light in the picture is based on that sensor.
Jun 18, 2018 at 8:11 PM
  • 9 POSTS
So the plug should impact positive light or negative with a tester? Plug is not showing positive light.
Jun 19, 2018 at 2:07 AM
  • 9 POSTS
The tester is not showing positive light on the plug?
Jun 19, 2018 at 2:09 AM
  • 9 POSTS
Sensor replaced. Water bottle was faulty and has been replaced together with its own sensor. now it is okay. Thanks again.
Jun 21, 2018 at 9:28 AM
Glad to help. Let us know if you have questions in the future.
Jun 22, 2018 at 6:51 PM
