Water coolant
2007 CHEVROLET OPTRA
140 MILES
UCHESTONE
  • 4 POSTS
Water Drains always from coolant reservoir while the car is stationary. I refill water every day in the coolant reservoir.
The car temperature is fine, it does not overheat. While driving the water level is always fine.
You only notice this drain the following day during routine check.
May 7, 2013 at 12:01 AM
MHPAUTOS
  • 31,937 POSTS
Start with a cooling system pressure test, this will help locate any external coolant leaks.
May 7, 2013 at 3:48 AM
UCHESTONE
  • 4 POSTS
Please what is he process of doing cooling system pressure test
May 7, 2013 at 5:41 AM
MHPAUTOS
  • 31,937 POSTS
There is a special tool for this, your local mechanic can do the test, it will take a min or two only to check.
May 8, 2013 at 2:10 AM
UCHESTONE
  • 4 POSTS
TNX
May 8, 2013 at 2:33 AM
MHPAUTOS
  • 31,937 POSTS
good luck,
May 9, 2013 at 2:56 AM
