I removed the tail light on a Maserati Ghibli because it had condensation. Used a heat gun to dy it and then left it in the sun. Placed clear silicone around the edges. Problem is before I even removed it is that when you hit the brake, the brake light on that side comes on for split second and goes off, and same if you repeat the process. Where it sits looks ok. removed the connector and had a bit of corrosion on one pin, cleaned it but same results. Bulb looks ok to me. Could a bulb be faulty and do this?
Feb 7, 2026 at 4:27 PM
