There are only a few places that coolant can go in an engine. You don't see an external leak or coolant in the oil, which suggests that it is likely a bad head gasket and the coolant is being used that way. This shows a few tests that can be done to determine if that is the case:
The pressure test and chemical test can usually be found as loaner tools at a parts store. I would suggest doing them and then you can decide what to do from there.
Jun 10, 2024 at 5:20 AM
