Water accumulation in fuel filter code keeps flashing
2015 TOYOTA REVO
40,000 MILES • 3.0L • 4 CYL • 4WD
SUNIL SINANAN
MEMBER
1 POST
FOLLOW
After replacing the fuel filter.The watering code keeps flashing and it is not coming off.
Apr 3, 2019 at 5:54 PM
SCGRANTURISMO
CERTIFIED EXPERT
Did you erase the code with your code reader after you fixed the problem? Another way to clear the code, although we can't really recommend it, is to take the negative battery terminal off the battery for five minutes. This will erase your vehicle's Keep Alive Memory (KAM).
