Good morning,
I would recheck your work and make sure you did not leave something disconnected. The crank sensor is behind the alternator. Make sure it is plugged in and not damaged.
GENERATOR REPLACEMENT
TOOLS REQUIRED
J 44811 Accessory Belt Tensioner Unloader
REMOVAL PROCEDURE
1. Turn the ignition OFF.
IMPORTANT: Record all pre-set radio stations.
2. Disconnect the negative battery cable.
3. Remove the throttle body air duct.
4. Remove the accessory drive belt.
IMPORTANT: Use the required J 44811.
5. Disconnect the generator electrical connections.
6. Remove the generator to engine block bolts and the generator.
Feb 11, 2021 at 1:31 AM
