Warning lights on dash board
2009 NISSAN QUEST
180,000 MILES • 3.5L • V6 • FWD • AUTOMATIC
HAWAZ MEZMUR DESTA
I have been getting TCS, ABS, service engine, and brake lights on and off. I have changed the two downstream O2 sensors, Bank1 and Bank2 Camshaft position sensors, 2 front ABS sensors. I also have checked the brake light switch with an Ameter and found it working okay, and the likes, but for no avail. Please help me. Thanks!
May 27, 2017 at 5:50 PM
STEVE W.
  • 15,113 POSTS
Sounds like you need to get the thing scanned to see what is wrong in the braking/ABS system. Could be a bad ABS sensor/wire/connector. Or a bad ABS control module. Without scanning it and getting the codes you will not know what to look at.
May 28, 2017 at 7:20 AM
