Interior lights not working and Starter not working right
2004 MITSUBISHI ENDEAVOR
173,000 MILES • V6 • 4WD • AUTOMATIC
JSMORGAN1IT
  • 6 POSTS
This entire thing started when our AC went out about two weeks ago. The fan and blower motor worked fine but all of a sudden no cold air. Took to mechanic who said AC compressor was bad. Had him replace it and AC was back to blowing cool air. Drove car for about two hundred miles then heard a hissing sound from dash, then came home and car would not start next day. It would crank fine but just would not cut over. Took back to same mechanic who said starter was bad. Replaced started car starts now but nasty sounding crank, lights flicker a bit too when cranked but also now the indicator, hazard, internal lights do not work and there is a weird dial circle on the radio display screen. Please help!
Feb 26, 2018 at 6:35 PM
This sounds like they got a bad starter or it is not installed correctly. Can you make a short video of the noise and upload it here so I can be sure of the issue?
Feb 28, 2018 at 11:00 AM
JSMORGAN1IT
  • 6 POSTS
When you crank it, it stutters, clicks then cuts over, definitely not as smooth as before. Though could this be related to a bad starter or starter installation? I have got some ground wires near the drivers side door that may have gotten wet when it rained recently because the weather stripping from the windshield is no good and my drivers side carpet was wet. May or may not be but just saying.
Feb 28, 2018 at 1:04 PM
JSMORGAN1IT
  • 6 POSTS
Someone told me that one of the relays could have gotten shorted out and that I should replace it or unplug the ETACS module and re-plug it back in. but not sure I should do that.
Feb 28, 2018 at 1:28 PM
Great job on the video. The starter motor is defective could be a cheap rebuild. I would use a OEM unit. Here is one from Amazon for 126.00
https://www.amazon.com/gp/product/B004J2CRC4/ref=as_li_qf_asin_il_tl?ie=UTF8&tag=2carprcom-20&creative=9325&linkCode=as2&creativeASIN=B004J2CRC4&linkId=c6d36ed16e4b6e398313cff8c499790d
This guide will show you how.
The door lock and interior light problem seems like a fuse #10 15 amp can you check it?
Mar 1, 2018 at 12:25 PM
JSMORGAN1IT
  • 6 POSTS
Ken, I had the starter replaced and that was a good idea thank you! Though I still have a problem with no turn signal or hazzard lights working. Do you know which relay controls them. Mechanic said all fuses were working fine but from your images I wasnt sure which exact fuses and relay we should check or try to replace.
Mar 2, 2018 at 3:34 PM
JSMORGAN1IT
  • 6 POSTS
Or Ken, do you have instructions on how to replace the ETACS ECU module?
Mar 2, 2018 at 3:54 PM
Lets start a new thread for this problem please.
Please post your question here
Mar 3, 2018 at 1:12 PM
JSMORGAN1IT
  • 6 POSTS
Ken, we were able to resolve the problem. It was in fact the ETACS module. I got another used module, popped it in and it worked. ETACS module controls interior lights, power locks, warning and hazard lights. Just replace it, its plug and play, no programming needed unless to re-program your keyless entry.
Mar 4, 2018 at 1:44 PM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Mar 5, 2018 at 11:00 AM
