Speedometer stopped working and multiple warning lights turned on
2006 FORD FUSION
70,000 MILES • 1.6L • MANUAL
STEWART MACDONALD
A cluster of warning lights have come on ABS, engine light, brake warning light. Also, speedometer has stopped working .
Jul 7, 2020 at 2:05 AM
Good morning,
There are fault codes stored for the lights on the dash. The ABS system is most likely the reason for the all the lights.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
You can go to a parts store and have them read the codes. At that pint, let me know the codes and I can help narrow the area of failure for you.
The speedometer not working is most likely the issue. There is a sensor for this but the code will confirm this for us.
Jul 7, 2020 at 4:43 AM
