Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Hyundai
Santa Fe
Engine
Throttle Body
Throttle Position Sensor
Replace/Remove
After replacing throttle position sensor engine runs worse and check engine light still on
2005 HYUNDAI SANTA FE
225,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
JACK ORTELLI
MEMBER
1 POST
FOLLOW
Just replace throttle position sensor. Started vehicle and check engine light still on and 4wd is blinking and car running worse?
May 2, 2020 at 12:04 PM
CERTIFIED EXPERT
Couple things. First what was the reason for replacing the TPS? Second what codes do we have now?
You are able to adjust this TPS so I attached the process just in case that turns out to be the issue.
Let me know what codes you have and we can go from there. Thanks
Image (Click to enlarge)
May 2, 2020 at 6:30 PM
