ABS light turned on
2010 SUBARU LEGACY
125,000 MILES • 2.5L • 4 CYL • AUTOMATIC
MLS69
  • 10 POSTS
The ABS light, traction control indicator light and brake light came on all at once. Brake light continually flashes. The battery cable was removed, checked brake fluid, and replaced brake lamp switch. Still not fixed. What do I do next?
Thanks for your help. MLS69
Dec 29, 2018 at 1:13 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
This means you have brake system trouble codes stored in your vehicles computer.First thing I suggest is to have the code(s) checked.If you don't have access to a code reader/scanner your local auto parts stores have a tool loaner program and can rent you one.Here is a tutorial showing what is involved:
Once you have the codes read get back to us with the code numbers and we will be happy to help properly diagnose.Hope this helps and thanks for using 2CarPros.
Danny-
Dec 30, 2018 at 4:41 PM
MLS69
  • 10 POSTS
Hello Danny,
Thanks for your speedy reply. The codes I have are P0500, C0071, C0073, C0074. Since I messaged you the check engine light, cruise control light, tire pressure light have all come on. Also, car does not want to go in reverse. Please help! Thanks, MLS69
Dec 31, 2018 at 9:23 AM
DANNY L
  • 5,648 POSTS
Hello again.
I've attached a picture below. Can you tell me which model?
Need to know if all wheel drive etc. Get back to me when you can and I will share repair information. Hope this helps and thanks again for using 2CarPros.
Danny-
Dec 31, 2018 at 4:44 PM
MLS69
  • 10 POSTS
Hello, I am not sure about the exact model. I don't have my title as of yet. It is AWD. Automatic. 2.5L. four cylinder. What else can I do to help diagnose? Thanks, MLS69
Jan 1, 2019 at 9:40 AM
The C0071 code is telling us the steering angle sensor has gone out which can cause the problems your are having. here is the information on changing it out:
Parts Information OEM Part Price Steering Angle Sensor
Position Sensor 27589AJ000 $359.70 HRS - 1.3
Clear the codes once complete this video will show you how.
https://youtu.be/rTtAnsOlZU4
Jan 3, 2019 at 11:13 AM
MLS69
  • 10 POSTS
Hello Ken and Danny L,
Thank you both for trying to figure out my car problems. We had to take the car to the dealer because every light on the dash came on! It ended up being the hydraulic unit or VDC. Thanks again for your help. Until next time...….MLS69
Jan 22, 2019 at 9:39 AM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help. Can you tell us what they charge you it fix it about?
Jan 22, 2019 at 10:36 AM
MLS69
  • 10 POSTS
A whole lot! Six hundred parts and six hundred labor. They had it about five or six hours. That is why we need people like you to help us out at times. Again, thanks for your input.
Jan 23, 2019 at 6:53 AM
Geez.. they didn't give that away. Please use 2Carpros anytime.
Jan 23, 2019 at 11:47 AM
