wanting to replace original 2.8l heads with 2.9l heads
1985 FORD
75,000 MILES • 2.8L • 6 CYL • 4WD • AUTOMATIC
DARRIN URBAN
I have a Ford 2.8l and I would like to put ford 2.9l heads on. I know there are some machine work needed, but not sure what this entails, what parts to use, head bolts, gaskets, push rods, etc. do you have any answers, or suggestions?
Sep 15, 2016 at 4:21 PM
CARADIODOC
  • 34,306 POSTS
What are you trying to accomplish? What model do you have and where did you find a 2.9L?
Sep 16, 2016 at 1:14 PM
DARRIN URBAN
I'm not really sure what I'm trying to accomplish, just heard it was possible and am wondering what machine work is necessary.
Sep 16, 2016 at 3:51 PM
CARADIODOC
  • 34,306 POSTS
With no other details, it sounds like you're trying to do an impossible job for no reason. A larger head usually has a larger "chamber" where the fuel and air gets squeezed into. That means with more area, less compression will result. Lower compression means lower horsepower. That is the goal only when adding a turbocharger. Turbocharging an engine with a normal compression ratio leads to all kinds of problems that almost always result in a destroyed engine.
I can't find a Ford model that even uses a 2.9L engine in the year you listed. If the head is from a different model, different year, or different engine size, it is very likely the intake manifold won't bolt up to it and the runners won't match up. Same goes for the exhaust manifold. I suggest you sell this car and buy what you want. Projects like this almost always end up in the front yard with a "For Sale As Is" sign in the window, and a box of parts in the trunk.
Sep 16, 2016 at 10:00 PM
DARRIN URBAN
There's really no reason to sell the car, as I was JUST curious in the first place. I was told it was possible... and as I previously stated, I was curious thank you for your response.
Sep 17, 2016 at 8:07 PM
CARADIODOC
  • 34,306 POSTS
Yup. Come back and see me when you have something I can really help with.
Sep 18, 2016 at 7:52 PM
