Need to know the position of the map air flow sensor
Apr 24, 2026 at 8:06 PM
CERTIFIED EXPERT
So there is no MAF sensor on this car, only a MAP sensor which is different, you can clean it but most of the time it is battery to replace it, the sensor in located at the top of the intake manifold. Check out the images (below). Let us know if you need anything else.
