Vz cluster inoperative
2006 HOLDEN SPORTWAGON
180,000 MILES • V6 • 2WD • AUTOMATIC
EDDIEEDWARDS
My car is a commodore Svz wagon. Temperature, tachometer, speedometer and the fuel gauges are inoperative as well as the LCD display. The left and right indicators appear on dash as well as high beam, pad lock light appears as normal. I have checked all fuses and tests come back fine. I removed the cluster from dash, and found the plug in good condition and installed correctly, I refitted to ensure. Still no good I assume the cluster has failed internally some how.
Mar 18, 2018 at 8:29 PM
MHPAUTOS
  • 31,937 POSTS
May be instrument cluster module, do you have any codes? Cluster failures are not that common a problem.
Mar 20, 2018 at 12:24 AM
EDDIEEDWARDS
Thank you for a prompt reply :). Unfortunately no codes up on the dash. I did disconnect the battery for half hour, as I read it may reset the ECM, this has fortunately fixed the issue, so far so good. I really appreciate your help. If I continue to have issue I will reconnect with you. Thanks again, Eddie :)
Mar 20, 2018 at 12:28 AM
MHPAUTOS
  • 31,937 POSTS
All good Eddie, that has done a minor re boot of the module, it may or may not be a permanent fix. Thanks for using 2CarPros.
Mar 20, 2018 at 12:35 AM
