Welcome back:
What I would suggest at this point is to remove the accessory drive belt that runs the alternator, A/C and so on. Start the engine for only a couple seconds to see if the noise is gone. If it is, inspect all belt driven accessories to see if there is any indicate a bearing problem.
Here are the directions for removing and installing the belt. The attached pictures correlate with the directions.
____________________________________________________
ENGINE CODE CNNA
Ribbed Belt
Removing
Risk of destroying due to a reversed running direction of a used ribbed belt.
Before removing the ribbed belt, mark the running direction with chalk or a felt-tip pen for reinstallation later.
- Remove the noise insulation. Refer to one of the following:
GTI and Tiguan
Eos and Passat
CC,
- Remove the right charge air hose - arrows -.
pic 1
- To release the tension on the ribbed belt, turn the tensioner in the - direction of the arrow - from underneath.
pic 2
- Secure the tensioner using the locking tool (T10060 A).
- Remove the ribbed belt.
Installing
Install in the reverse order of removal. Note the following:
Before installing the ribbed belt, the generator and Air Conditioning (A/C) compressor must be installed securely.
- First, install the ribbed belt on the vibration damper, then on the A/C compressor and generator.
pic 3
- Turn the tensioner using a box end wrench and remove the locking pin (T10060 A).
pic 4
- Release the tensioner.
- Check whether ribbed belt is routed correctly.
- Start the engine and check whether the ribbed belt runs correctly.
The last picture I attached is an exploded view of the drive belt assembly.
Let me know what you find.
Sep 1, 2019 at 5:46 PM
