Camshaft VVT solenoid cannot find the second location?
2019 MITSUBISHI OUTLANDER
155,555 MILES • 2.4L • AUTOMATIC
ZURIELIZCOLON
I seem to think the Mitsubishi has one VVT solenoid instead of two can’t find the second location and a Mitsubishi mechanic says there’s one is that true?
Jul 30, 2025 at 1:15 PM
CANNON1349
  • 861 POSTS
Hello, there are 2 parts listings for the VVT Solenoid, intake and exhaust. They should be positioned across from one another, and being a 4-cylinder engine this should be easy to spot. Please post a picture if you have any difficulty finding the solenoids.
William
Jul 30, 2025 at 6:30 PM
STEVE W.
  • 15,113 POSTS
Mitsubishi used two different 2.4 engines in that vehicle year. One is a single overhead cam with a very unique VVT system on that engine. Unlike the typical method of just using a phaser they used a motor on a rockshaft as well. There is the single cam position sensor on the end of the rocker housing below the oil filler cap which is controlled through a single oil flow solenoid that moves the camshaft phaser, they also used a valve lift control motor that was part of the carrier assembly (14 in the picture) and it was adjustable via the motor on the opposite end of the rocker cover. That has its sensor built into the motor.
The other is a dual overhead cam engine which does use two sensors. Which engine version do you have?
Jul 30, 2025 at 8:48 PM
