Yes, this vehicle has an OBD2 system. However, here is what I suggest. Your vehicle and newer vehicles have what is called a CAN system (can-bus). CAN stands for controller area network. Basically, all the modules/computers together via a few wires.
Now, a basic OBD2 scan tool can't read codes from all the modules, so you need to have a CAN scanner to do it. Here is a video showing it being done. Basically, it is the same as an OBD2 scanner, it just has more options.
https://youtu.be/InIlnsjOVFA
I am suggesting this simply because a scanner is something you will likely have for many years. You will benefit from having this for your car now and as you get newer ones.
As far as cost, check out Amazon for OBD2 scanner that can read the CAN. They are no more expensive than a traditional OBD2 scanner.
Check it out and let me know if you have questions. Also, please know that I am suggesting this only because I feel you will benefit from it. I have nothing to do with Amazon. It's just a suggestion.
Aug 24, 2021 at 7:11 PM
