we put new tires, balanced, aligned it, new brakes and rotors ll around. I just could not get to why it was giving the vim and check engine light. so took it to the dealer to see why it is still having a shake, even though we replaced all mounts except the rear engine one as it's difficult. they called telling me the rear O2 causing the VTM and check engine light, $530.00. the D was started to flash, I told them that never happened, but okay, they said needs a transmission now, and they recommend a balance and an alignment, I said I just had that done. so I am going to get it and see if I can replace that rear oxygen sensor he is talking about, this is supposed to be on the exhaust before reaching the catalytic correct? the transmission I will see what is going on because it never did flash and he saying not won't shift out of 3rd gear, It only had a delay in 1st. geez
Sep 1, 2020 at 2:10 PM
